2001 Kz100p Engine leak?
- 09marty
10 Apr 2020 21:53 - 10 Apr 2020 21:54
I get an oil buildup right in these areas and the two bolts next to them are tight. Any ideas of the cause?
Last edit: 10 Apr 2020 21:54 by 09marty.
Re: 2001 Kz100p Engine leak?
10 Apr 2020 22:28
Cam cover gasket or seal at cam cover end plug
The following user(s) said Thank You: 09marty
11 Apr 2020 07:02
Yup. Looks like there may be some seepage around the bolt going through the exhaust cam plug. The plugs are rubber and get brittle after a while. Might as well check valve clearances as long as you have the cover off for gasket and plug replacement.
