Valve shims
  • Wagner
  • Wagner's Avatar Topic Author
Valve shims
31 Mar 2020 19:30 - 31 Mar 2020 19:33
#822344
I have a 1981 k550. I have to change a few shims. My question is, do you rub a little clean oil on the shims and under the bucket or clean them off good and then install. I am thinking of cleaning them off so the light film of oil doesn't affect my gap measurement. Just looking for some input. Thanks.
Last edit: 31 Mar 2020 19:33 by Wagner. Reason: Spelling
  • kevski
  • kevski's Avatar
Re: Valve shims
31 Mar 2020 23:19
#822350
Smear a little oil on them , if you have done the maths correctly this will not be a problem, also when the motor is running a fine film of oil will be under the shim anyway.
The following user(s) said Thank You: bartman
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: Valve shims
01 Apr 2020 01:42
#822354
..it is supposed to have oil....that why the valve stem oil seals.
  • Wagner
Re: Valve shims
04 Apr 2020 20:09
#822634
Thanks everyone. New shims installed. Clearances within the upper and lower limits.
  • loudhvx
  • loudhvx's Avatar
Re: Valve shims
07 Apr 2020 08:36
#822794
Make sure to release the cam chain tension before re installing the cover. The details are in my signature.
If you havent, you can still do it now.
