kz750 to 700 cylinder heads
  • gixxerkidd03
  • gixxerkidd03's Avatar Topic Author
30 Mar 2020 22:58
#822249
does anyone know if the kz750 and kz700 cylinder have the same size combustion cambers and valve sizes. i know carbs will mount and exhaust will mount. im wondering if i use 750 cams do i have a 750 head, or is the combustion chambers different?.
i screwed up a 750 head but have an extra 700 head.
1981 KZ750e
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: kz750 to 700 cylinder heads
31 Mar 2020 03:26
#822252
I don“t think Kawasaki made any combustion cambers modifications on the 700 ccm Cylinder Head, exept the cylinder bore size. I would try to compare the 700/750 head gaskets first.
  • Nessism
  • Nessism's Avatar
31 Mar 2020 05:41
#822255
Kawasaki moved to a bathtub combustion chamber shape on later 750's so that may be one thing. Another being the lack of mechanical tach hole.
  • TexasKZ
  • TexasKZ's Avatar
31 Mar 2020 06:31 - 31 Mar 2020 06:36
#822266
According to Partzilla, the KZ700 cylinder head has a unique part number, and the head gasket is different from earlier models, but is the same as the later 750s, including the Zephyr. Exactly what the differences are, I do not know.
The diagrams also show an electronic tachometer on the 700.
Last edit: 31 Mar 2020 06:36 by TexasKZ.
