Firing order
  • Zephy 750
  • Zephy 750's Avatar Topic Author
Firing order
19 Mar 2020 22:11
#821254
Hey everyone I am new here and I just recently got a 1980 kz 750 but I can't figure out the firing order please help
  • hardrockminer
  • hardrockminer's Avatar
Re: Firing order
20 Mar 2020 05:20
#821264
If it's a 4 cylinder it's likely 1-2-4-3.
  • martin_csr
  • martin_csr's Avatar
Re: Firing order
20 Mar 2020 07:14 - 20 Mar 2020 07:25
#821268
Also, the #1 & #4 spark plug wires should be connected to one ignition coil (probably the RH), and #2 & #3 to the other coil.
And the black igniter wire goes to the 1/4 coil, while green goes to the 2/3 coil. Each coil has a red wire.
750turbo.com >>> Downloads >>> Full manual (128mb PDF) .
80-85 750-4 chain drive manual. Yellow/gold cover w color wiring diagrams. 1980-84 KZ750-4 & KZ700. 1983-85 ZX750.
ps: the good manual may be linked here on KZR in the Filebase.
Wiring diagrams. mbsween. bike-night. KZ750L3. Scroll down & click "The Bible" link.
note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
The site has a poorly copied black-&-white 750-4 pdf manual, so be sure to get the good version from the 750Turbo site linked above.
Last edit: 20 Mar 2020 07:25 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
Re: Firing order
20 Mar 2020 07:47 - 20 Mar 2020 07:49
#821271
If you have a 750 twin, the firing order is 1-2, and it does not matter which plug wire goes where.
It is helpful to put your bike info in the signature line so that readers will know exactly which model you are asking about and you will not have to put the info in every post manually.
Last edit: 20 Mar 2020 07:49 by TexasKZ.
  • hardrockminer
Re: Firing order
21 Mar 2020 05:07
#821283
On 4 cylinder Kawasakis the left coil (from seated position) feeds 1 & 4. The right feeds 2 & 3.
  • martin_csr
Re: Firing order
21 Mar 2020 05:43 - 21 Mar 2020 05:46
#821287
By hardrockminer: On 4 cylinder Kawasakis the left coil (from seated position) feeds 1 & 4. The right feeds 2 & 3.
I think the 1000s are opposite from the 650/750 models. :)
ps: if it's a Twin, then never mind both of my replies.
Last edit: 21 Mar 2020 05:46 by martin_csr.
