Help!
  • mothradeath
  • mothradeath's Avatar Topic Author
Help!
17 Mar 2020 16:12
#821112
Does anyone know of a how-to vid to walk me through doing a gasket change? Sucker is leaking in multiple spots. It's a 1979 kz750b twin. Thanks
  • mopguy
  • mopguy's Avatar
Re: Help!
17 Mar 2020 17:06
#821116
I am not able to see the pictures you posted, but make surethe surface is clean, and then torque the screws to specifications.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Last edit: 17 Mar 2020 18:29 by Scirocco.
  • TexasKZ
  • TexasKZ's Avatar
Re: Help!
18 Mar 2020 06:38 - 18 Mar 2020 06:42
#821144
Which gasket do you want to change?
Have you consulted the service manual?
www.kzrider.com/modules/ServiceManuals/K...l%20KZ750%20Twin.pdf
Last edit: 18 Mar 2020 06:42 by TexasKZ.
  • mothradeath
Re: Help!
18 Mar 2020 09:29
#821165
TexasKZ wrote: Which gasket do you want to change?
I picked up a gasket kit and they all seem like they would be pretty straight forward to do.....but the head gasket has me a little scared with what it takes to do it. Thanks for the manual link.
