GPz550 won't shift into second gear
- dpivas7
16 Mar 2020 15:52 - 16 Mar 2020 16:04
I am working on a 1984 GPz550 that I sold to my buddy a few years ago. He's having trouble shifting into second gear.
When the clutch is pulled, it will shift into first and neutral, but you can't upshift into 2nd. I'm guessing it's a bent shift fork, but this is my first time working on transmissions.
Can anyone help me out? Thanks!
Edit: The bike isn't running when I'm trying to shift. I think I read somewhere that you can't shift into second when the bike isn't rolling.
In any case he had an issue where the bike popped out of gear while cruising in second. Maybe a false neutral? I'm not even sure what that is.
I was ruling out it being a clutch issue due to the fact that he said he wasn't revving very high when it happens so I don't think there's any slippage occurring.
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
Last edit: 16 Mar 2020 16:04 by dpivas7.
- baldy110
Re: GPz550 won't shift into second gear
16 Mar 2020 16:09
That's normal, The bike will not shift from neutral to second unless it's moving or the rear wheel is spinning. It's called a neutral finder, Kawasaki installed 3 ball bearings in the transmission that prevents over shooting neutral while stopped. When the bike is moving those ball bearings fling outwards because of centrifugal force allowing the rider to shift from neutral to secind.
16 Mar 2020 16:22
What baldy said plus---
If it slipped out of second only once, it could have been the result of sloppy shifting. If it happens more, then a bent shift fork or damaged engagement dogs are likely the cause.
Sometimes also caused by a broken or weak shifter return spring. This is the easiest to fix.
- RonKZ650
16 Mar 2020 20:26
Kawasaki must really regret putting the benefit of shifting to neutral at a stop without the work of not shifting to second. Question has been hashed over 1,000 times or more just here.
17 Mar 2020 07:22 - 17 Mar 2020 07:22
By dpivas7: .... In any case he had an issue where the bike popped out of gear while cruising in second. Maybe a false neutral? I'm not even sure what that is. I was ruling out it being a clutch issue due to the fact that he said he wasn't revving very high when it happens so I don't think there's any slippage occurring.
I wouldn't depend upon anything the previous owner said. some guys don't know what they're going & aren't truthful. and sometimes do the wrong things.
Last edit: 17 Mar 2020 07:22 by martin_csr.
- dpivas7
18 Mar 2020 06:54TexasKZ wrote: What baldy said plus---
Is a bent shift fork as easy to fix as it sounds? Do you just replace the fork or is it no that simple? I'm going to ride the bike and see if I can simulate the issue he had, but I just want to know for future reference.
