Questions: kz550ltd shaft timing marks or maula
- prichmon
26 Feb 2020 17:27
Does anyone have a manual for the 550 shaft drives?
Does the secondary drive unit have its own oil supply?
Can anyone take a pic of the timing marks on the pick up coil rotor and bracket?
I would very much appreciate the support.
Thanks all.
Thanks all.
Re: Questions: kz550ltd shaft timing marks or maula
27 Feb 2020 11:41 - 29 Feb 2020 05:34
What year is it? The 84 550-F2 had a pulsing coil rotor, instead of a mechanical timing advancer found on most KZs.
The drive shaft lubrication is separate from the engine oil.
AFAIK, there isn't a pdf manual for any of the KZ shaft drive models.
A number of manuals are listed on EB at reasonable cost. EB search = KZ550 shaft manual.
Kawasaki FSMs have a model application chart on the back cover, so make sure your motorcycle is on the list.
1981 KZ650-CSR. the 550-M1 Shaft is similar, as are most KZs.
note: use a 17mm wrench to turn the crankshaft. do not turn it using the smaller advancer bolt.
Last edit: 29 Feb 2020 05:34 by martin_csr.
- prichmon
28 Feb 2020 11:11
Thank you for the response.
The bike is an 84 shaft 550ltd. I see the T timing mark on the rotor but don't see a mark on the case. When we opened up the timing cover there is significant corrosion inside the area.
29 Feb 2020 05:35 - 29 Feb 2020 06:12
I couldn't find a good EB pic, but from the photos I saw your engine timing mark should be pretty much the same as the 650. I would scrub it with a stiff nylon brush or something. The Partzilla diagrams & EB pics are handy for stuff like this.
Last edit: 29 Feb 2020 06:12 by martin_csr.
The following user(s) said Thank You: prichmon
- prichmon
03 Mar 2020 06:29
Based on your recommendations and the pic; I removed the timing plate to find a timing mark just like yours. I don't believe I've ever removed a timing plate to see a timing
mark.
Once it was in time I struggled a little while getting it to run as it seemed to be out of time. I took a guess the coils were wired backwards. The bike fired up and ran really well.
Next I tackle float height to get the a/f ratio closer to each other as it ran cooler left to right.
Thank you very much.
mark.
03 Mar 2020 07:19 - 03 Mar 2020 08:08
By prichmon: Based on your recommendations and the pic; I removed the timing plate to find a timing mark just like yours. I don't believe I've ever removed a timing plate to see a timing mark. ....
You probably shouldn't have to remove the pulsing coil to see the timing mark, so that you can use a strobe light.
For the chain drive models: in the ZX550 supplement manual the timing mark is visible with the pulsing coil in place, including models with the pulsing coil rotor.
Last edit: 03 Mar 2020 08:08 by martin_csr.
