valve shim question?
  • lhemrick
  • lhemrick's Avatar Topic Author
19 Feb 2020 06:03
#819567
Where is the cheapest place to order shims for a valve adjustment? This is all new to me because everything else I own can be adjusted with a screwdriver and a wrench. Thanks!
  • 73z1
  • 73z1's Avatar
Re: valve shim question?
19 Feb 2020 06:36 - 19 Feb 2020 06:38
#819570
Only use Kawasaki shims from dealer or ebay search "kawasaki oem z1 shim"
Some after market shims have failed, to risky, use Kawasaki only.
Last edit: 19 Feb 2020 06:38 by 73z1.
The following user(s) said Thank You: hardrockminer
