'79 KZ650SR Compression Low
  • kgkomm
  • kgkomm's Avatar Topic Author
16 Feb 2020 18:17 - 16 Feb 2020 18:40
#819467
This weekend, I tore apart the engine in my '79 KZ650 SR because my compression was low (50-70 psi across all 4 cylinders with a slightly warm engine test). I replaced the head gasket and all the piston rings. I checked to make sure the valves weren't leaking. I put it all back together tonight and checked the compression. Essentially no change. It's still about 50-70 across the board, and I'm about ready to pull my hair out.
I tested each cylinder while cold (haven't run the bike in several weeks) with the other spark plugs in because I didn't know that it could make a difference. The carbs are off with only the intake boots attached. The exhaust is also off because I had it up on a motorcycle jack to work on it.
I'm planning on putting a little oil in each cylinder tomorrow and running the bike for a bit before I test it again because I've read that those can both make a difference. But I feel like those things adding almost 100psi is a longshot.
Is that low of a reading normal for a cold engine? I need all the help I can get. Thanks guys!
Last edit: 16 Feb 2020 18:40 by kgkomm.
  • Nessism
  • Nessism's Avatar
Re: '79 KZ650SR Compression Low
16 Feb 2020 18:58
#819468
Did you adjust the valves and bottle brush hole the cylinder bores?
The engine will need some miles before the rings seat.
  • hardrockminer
  • hardrockminer's Avatar
17 Feb 2020 06:09
#819481
My first thought is to check the gauge. My second is to check timing and valve clearance.
17 Feb 2020 07:25
#819485
I'm surprised the engine ran with 50-70 compression. If that is really an accurate number it is awfully low. Ed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
17 Feb 2020 11:39
#819497
Maybe he forgot to pull full throttle on the carbs.
  • kgkomm
17 Feb 2020 11:43
#819498
From these comments, maybe my gauge isn't any good? I bought the compression tester new off of Amazon. The brand is BlueDriver I think and it had good reviews. Maybe I got a faulty one, who knows.
I've done the valve clearances and checked them. All at 0.15 mm, or within spec. I will check my timing again. I set it according to the clymer manual I have.
  • kevski
  • kevski's Avatar
17 Feb 2020 12:38
#819501
Engine needs to be at operating temperature, remove all 4 plugs, disconnect power to the coils and spin over for ten seconds on each cylinder with wide open throttle, you will then get a true reading, but before you do this put a few miles on it at various engine speeds to bed the rings in again.
