Replacement down pipes
  • smiddl
  • smiddl's Avatar Topic Author
25 Jan 2020 13:48
#817879
Anyone know good supplier of replacement downpipes for 79 Z750 twin? they are needed for standard 2 into 2 system
  • TexasKZ
  • TexasKZ's Avatar
Re: Replacement down pipes
01 Feb 2020 07:06
#818349
I suspect if anybody still makes an exhaust system for the 750 twin, it would be Jardine. If you still have a pipe , a high quality custom exhaust fabricator should be able to replicate it. I would avoid common muffler shops as they will likely not have small enough tubing and cannot make mandrel bends.
The following user(s) said Thank You: smiddl
