KZ750 GPZ750 Sproket Cover
  • Chamber66
  • Chamber66's Avatar Topic Author
12 Jan 2020 01:42
#816951
Hi
Does anyone know where I can get an aftermarket sprocket cover for the KZ750/Gpz750? Similar to the ones below
  • Nessism
  • Nessism's Avatar
Re: KZ750 GPZ750 Sproket Cover
12 Jan 2020 05:13
#816955
The clutch release actuator is built into the sprocket cover so...
  • Chamber66
18 Jan 2020 00:02 - 18 Jan 2020 00:03
#817330
No eBay APP ID and/or Cert ID defined in Kunena configurationI changed mine to the type which is actuated from the clutch cover
Not mine but like this
Last edit: 18 Jan 2020 00:03 by Chamber66.
  • TexasKZ
  • TexasKZ's Avatar
19 Jan 2020 18:15
#817464
Maybe contact PDM and see if he can make one for you.
The following user(s) said Thank You: Chamber66
