Smog holes
- Sayonara
- The faster the better
Smog holes
07 Jan 2020 06:32
Hello I was wondering what is the best way to block the smog holes on an MKII engine head, I did block them in the valve cover but it leaks in the trough the gasket,
when I bought the gasket I was sen a thin gasket so I ordered 2 more with seems to be thicker as OEM to fit them, but I was wondering if there is a way maybe using an aeronautic epoxy that I used before to fix a crack that was leaking oil and stoped.
any suggestions are welcome.
Thanks
Thanks
I grew up riding and fixing all sort of small bike until I inherited A 1977 GS 750 when I was 16, that changed my life completely I love metric bike and I own a few fully working and have some projects.
- zed1015
Re: Smog holes
07 Jan 2020 08:26
The holes in the head are just the right size to tap m10 and seal with a grub screw.
