650 clutch issue
- spearo65
650 clutch issue
30 Dec 2019 14:56
hey guys i am having trouble getting my 78 kz650 started, the clutch will spin when i try and kick start it but the timing chain and valves don't move, any help is appreciated ty!!
Re: 650 clutch issue
30 Dec 2019 15:11
By any chance are you pulling in the clutch lever? Ed
- spearo65
- kevski
30 Dec 2019 23:23That's the problem to the answer, neutral, clutch out, choke lifted, gas on, kick in a downward motion leaving throttle alone, and as long as everything is ok it will start.spearo65 wrote: yes of course
- baldy110
31 Dec 2019 07:48
To kicksart the kz650 it has to be in neutral with no clutch. With clutch pulled all your doing id spinning the transmission.
31 Dec 2019 12:02spearo65 wrote: yes of course
That's the problem. Don't pull in the clutch lever when kick starting the bike. Do pull in the clutch lever when using the electric starter. Ed
31 Dec 2019 13:00
- spearo65
31 Dec 2019 15:48
thanks guys gunna put everything back together and try again
- spearo65
02 Jan 2020 09:39
so i kicked the bike and it is cycling through the cylinders however the clutch is still spinning a considerable amount, any thoughts?
02 Jan 2020 09:46
Is the clutch spinning more than the output shaft of the transmission? Can you post a short video?
- loudhvx
02 Jan 2020 18:39
The clutch is supposed to spin when you kick start the bike.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
