Rubber sleeves?
- Kiddynamite8
Rubber sleeves?
30 Dec 2019 10:25
Hi guys...another question that has me stumped.
When I removed the oil pan some of the bolts had rubber sleeves over them. I looked on partzilla and it looks like the replacement bolts don't have those sleeves.
Are they needed? And where would I get them? I don't know what they are actually called.
Thanks.
Thanks.
1978 KZ650
- z1kzonly
Re: Rubber sleeves?
30 Dec 2019 10:51
I got a feeling that you are seeing RTV silicone. From someone re-assembling at 1 time??
The following user(s) said Thank You: Street Fighter LTD, Kiddynamite8
- zed1015
Re: Rubber sleeves?
30 Dec 2019 11:29
As Above.
No such thing as rubber sleeves for those bolts or any on these bikes..
A previous owner had gone overboard with the silicone sealer on an old gasket.
Probably more of the same partially blocking the oil pump pick up ..
The following user(s) said Thank You: Kiddynamite8
- Kiddynamite8
Re: Rubber sleeves?
30 Dec 2019 11:36
Ok. Thanks. So I can just use the bolts as they are...no need for 100 pounds of silicone? Haha!
Thanks guys.
Thanks guys.
1978 KZ650
- spdygon
Re: Rubber sleeves?
30 Dec 2019 19:46
Nope and do not over torque them ....torque to 98 in lb or 8 ft lb
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Re: Rubber sleeves?
31 Dec 2019 06:01
I think 98 in lbs might be a bit high. Z1 torque spec is 70 for sump bolts.
