Is that my starter clutch making that noise?
- stuconz
29 Dec 2019 23:08
Hi all,
have had the KZ440 bike running recently and this morning when I went to start it to do some further timing analysis, it made a lot of whirring spinning noises.
Is it the starter clutch I'm hearing making that racket?
See link:.
Starter clutch noise? (youtube)
Thanks!
See link:.
Thanks!
1981 KZ440 (rebuild:
stuconzblog.wordpress.com
- Stu23
Re: Is that my starter clutch making that noise?
30 Dec 2019 02:41
Doesn't sound great, does it? I had a z400 for years and it always screamed as it disengaged... did it for years without issue.
That's definitely not the same. Sounds like a loose chain is getting rattled by the low tick over.
I suspect the starter clutch is dragging and not disengaging properly.
The following user(s) said Thank You: stuconz
- stuconz
31 Dec 2019 15:25
Cheers. I took the flywheel cover off and the chain was very loose. Too much play in my opinion, but then that could be completely normal...
Youtube vid of loose chain?
- loudhvx
03 Jan 2020 12:29 - 03 Jan 2020 12:34
As long as the sound is coming from the chain and starter clutch area, I wouldn't worry about it. Because the motor is not actually starting, there will be some oscillation (or lash) in the chain and starter sprocket and could cause the starter clutch rollers to jiggle about and make noise. (The starter chain and starter sprocket don't turn while the engine is running.)
If it was making that type of noise at idle or higher RPM, then you might consider looking at the primary chain or balancer chain for excessive play. But even that noise is pretty common until the bike warms up and the idle smoothes out.
The first video sounds much worse than the second. Once the bike gets running, the bearings of the starter clutch will get pressurized oil . That might make it quiet down on subsequent starts.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 03 Jan 2020 12:34 by loudhvx.
