KZ750 Ring Gap Question
- Your_Boy_Yuriy
26 Nov 2019 05:41
Hello,
I believe the block is from a 1982 KZ750 and the head is 1983 GPZ
What is the recommend first and second ring gaps values. The service manual only states the service replacement limit of 0.7 mm I believe.
Here are my measurements: All measurements were taken at the depth.
Cylinder 1: F: .406 mm S: .483 mm
Cylinder 2: F: .381 mm S: .381 mm
Cylinder 3: F: .381 mm S: .381 mm
Cylinder 4: F: .330 mm S: .483 mm
Cylinders 1 and 4 also had some oil stains on the walls. That might explain why the gaps are slightly larger. Also this is my first time measuring, so there might be some user error.
How would I figure out the minimum gap clearances?
1982 KZ550C (First love)
1979 KZ650 (project Bike)
2007 Ninja (Project bike)
2020 Tracer GT (current love)
Chicago Western Suburbs
Re: KZ750 Ring Gap Question
26 Nov 2019 07:54
Those end gaps are fine. I'm not sure what the new factory spec is but it's tighter than what you are measuring. As a data point the Suzuki GS750 has a new spec of .1-.3mm and a service limit of .7.
26 Nov 2019 18:21 - 26 Nov 2019 18:25
Last edit: 26 Nov 2019 18:25 by TexasKZ.
