KZ440 Camshaft help needed?
- Elsebu
23 Nov 2019 11:53
I looking to find some specific info about performance camshaft for a kz440. Previous owner had swapped new valves and propably got the timing wrong.. Exhaust valves had made contact with pistons when starting up and both are bent. The head is now ported and waiting to be rebuilt but i noticed that the cam lobes are pretty worn out so I taught that I would get them refilled and on the same occasion maybe get more lift and degrees. The problem is that i dont have knowledge of this type of engine so any suggestion of the cam profile would be helpful. I have been tuning and playing with 2cv boxer engines but bike engines are something new for me so any help would be nice.
Re: KZ440 Camshaft help needed?
24 Nov 2019 19:26
Have you checked Web Cams? They make cams for a wide cariety of vehicles.
- Elsebu
25 Nov 2019 12:05
Yes, and got specs for one. Does any one on forum had one?
Intake Exhaust
Valve Lash (Inch): .005" .006"
Valve Lift (Inch): 0.300 0.300
Valve Lift (mm): 7.62 7.62
Advertised Duration: 258° 258°
Duration @ 0.050": 230° 230°
Lobe Center: 111.5° 111.5°
Intake Opens 3.5° Before TDC Exhaust Opens 46.5° Before BDC
Intake Closes 46.5° After BDC Exhaust Closes 3.5° After TDC
Intake Exhaust
