Oil Pressure Gauge - KZ1000J
- grumpy56
02 Nov 2019 09:15
Hello all. I bought an oil pressure gauge for my J model and broke the supplied brass fitting off when I was tightening it. It leaked like a sieve when I thought I had it "just tight enough", but it broke. Was able to get the remnants out OK. The "flat" on my oil bolt, with a rubber washer is about twice the size of the brass fitting that came with the oil gauge. Would like to have a stainless bolt as large as the normal plug (P/N 92066-021 which is 14X12) that I can tap into. Any suggestions? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Barry1
Re: Oil Pressure Gauge - KZ1000J
02 Nov 2019 22:21
When you replace it don't be stingy with the Teflon tape.
- grumpy56
03 Nov 2019 03:34
Good point as I did not use any.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
