80 KZ550 LTD engine gasket set
  • Buzzard53
  • Buzzard53's Avatar Topic Author
30 Oct 2019 16:17
#813293
Long time since I have posted.
The 1980 LTD cafe project has been steadily progressing. Getting ready to get into the motor.
I was given a after market eng gasket set labeled for KZ550 A1/A3. Would this be compatible with my KZ550 C1?
Thanks!
1980 KZ550 LTD
2016 HONDA GOLDWING F6B
U.S.A.F. 1972-1976
  • martin_csr
  • martin_csr's Avatar
Re: 80 KZ550 LTD engine gasket set
31 Oct 2019 05:13 - 31 Oct 2019 05:17
#813307
Probably yes, but you can compare gaskets at Partzilla.
What brand is the set? I don't know much about it, but I would probably use oem gaskets in some cases, such as the cylinder base gasket & head gasket.
Last edit: 31 Oct 2019 05:17 by martin_csr.
