Ready for next step
  • Kiddynamite8
  • Kiddynamite8's Avatar Topic Author
Ready for next step
28 Oct 2019 15:12 - 28 Oct 2019 15:13
#813179
Ok guys, thanks to all your help, I'm ready to clean these pistons and get this thing going!
My next question is how should I go about cleaning?? There is a bunch of crap all over and I don't want it all falling into the bottom.
Any advice is ALWAYS appreciated greatly.
1978 KZ650
Last edit: 28 Oct 2019 15:13 by Kiddynamite8. Reason: Typo
  • hardrockminer
  • hardrockminer's Avatar
Re: Ready for next step
28 Oct 2019 15:16
#813182
You should probably pull the piston wrist pins and remove the pistons. The wrist pins will have a small wire circlip on each end. Remove one ant then tap the pin gently from the opposite side to remove it. Soak the pistons and use an ultrasonic cleaner.
The following user(s) said Thank You: Kiddynamite8
  • Nessism
  • Nessism's Avatar
28 Oct 2019 16:51 - 28 Oct 2019 16:53
#813191
Agree with removing pistons. Be sure to mark them so you know which hole they came from. The cylinders are numbers 1 to 4 from left to right when sitting on the bike.
Carb dip works well to remove carbon and varnish.
Last edit: 28 Oct 2019 16:53 by Nessism.
  • Kiddynamite8
28 Oct 2019 16:57 - 28 Oct 2019 16:58
#813192
Thanks for the help! I don't have an ultrasonic cleaner, so I will try the carb dip.
Thanks!
1978 KZ650
Last edit: 28 Oct 2019 16:58 by Kiddynamite8. Reason: Typo
  • gordone
  • gordone's Avatar
28 Oct 2019 23:33
#813203
I suggest fill paper in the wholes to avoid less dirt as possible to fall down into the crankcase.
Project:
