Piston Ring Set
- Kiddynamite8
Piston Ring Set
28 Oct 2019 08:12
1978 KZ650:
I'm looking on partzilla and there are are a few different sets.
Do i need the RING SET,PISTON,STD or the RING SET,0.040in.,O.S.? The .020 is sold out.
Thanks!
Thanks!
1978 KZ650
- Warren3200gt
Re: Piston Ring Set
28 Oct 2019 08:16
Do your pistons have a number on top? If not they are standard, if they have +1 or 20 they are first bore oversize. If they have +2 or 40 they are second bore oversize.
The following user(s) said Thank You: Kiddynamite8
- Kiddynamite8
Re: Piston Ring Set
28 Oct 2019 08:28
Thank you!
I will have to clean the pistons up a bit before i can see any numbers! They are pretty bad!
1978 KZ650
- DoctoRot
Re: Piston Ring Set
28 Oct 2019 12:30 - 28 Oct 2019 12:30
before you buy pistons rings measure the cylinder bores to make sure they aren't oval or tapered, and check the pistons to cylinder clearance. if they are out of spec you will need to overbore.
Last edit: 28 Oct 2019 12:30 by DoctoRot.
