First start after long storage.
  • Davey b
  • Davey b's Avatar Topic Author
23 Oct 2019 11:52
#812903
Hi all, just bought a kz 1000 m1, 1980.
It's been dry stored for 23 years, any recommendations on the best way to spin it over for the first time. Dont want to do any damage.
1981 kawasaki kz1000 m1 csr
  • DoctoRot
  • DoctoRot's Avatar
Re: First start after long storage.
23 Oct 2019 12:25
#812905
new oil, new gas, make sure it turns over by hand, pull the spark plugs and look at them carefully to see if there is any damage indicating a previous issue. Then crank it for several seconds with no spark plugs in it till the oil pressure light goes out. then start it up as normal. If you want to be extra careful you could pull the valve cover off first and lube up the cams before cranking it at all.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Oct 2019 12:28
#812906
Put a teaspoon of oil in each cylinder and turn it over with the plugs out first.
  • Davey b
23 Oct 2019 13:12
#812907
Thanks Steve, can I turn it manually some how or off the starter ??
23 Oct 2019 13:37
#812910
If you don't want to use the starter just put the bike in gear and turn the rear wheel. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Oct 2019 14:39
#812911
You can use a 17mm wrench on the crank under the timing cover. I wish I had done that when I got my bike running after 15 years. Could have saved a piston.
The following user(s) said Thank You: BCScott, Davey b
  • azman857
  • azman857's Avatar
23 Oct 2019 19:55
#812920
I would do a complete Tune up. Carb overhaul, oil change and valve adjustment. The pouring of oil into the cylinders and over the valves/cams is worth doing also. Don't use the starter until you know the pistons are free and the cylinders are lubed. If there is a kick start, use that to turn the engine over until some oil is moved through the engine.
  • Davey b
24 Oct 2019 00:36
#812924
Yeah, good advice. Plan on doing a complete overhaul at some point in the future, but first I need to check that nothing is seized. Gonna be a long slow process cos of work etc etc..
