82 Kawasaki kz750m
- Cruzn74
82 Kawasaki kz750m
20 Oct 2019 20:46
Hey everyone I have an issue that I hope someone could help I've been working on my kz750 the other day i went to do a compression test after hooking it up and using the kick starter it got stuck after two kicks now it wont kick unless I hold in the clutch so my ? Is if that’s normal cuz i never had to do that before does that mean the engine is locked up
- AtLarge
Re: 82 Kawasaki kz750m
27 Oct 2019 06:46Cruzn74 wrote: Hey everyone I have an issue that I hope someone could help I've been working on my kz750 the other day i went to do a compression test after hooking it up and using the kick starter it got stuck after two kicks now it wont kick unless I hold in the clutch so my ? Is if that’s normal cuz i never had to do that before does that mean the engine is locked up
Free bump for you since I have nothing specific to help. I doubt the engine is locked up via the pistons and more likely something is amiss with your kick start mechanism. Pulling the clutch is just a release so, your not moving anything internally. Remove the other plug and compression test fitting. Put a socket on the crank at the timing advance and try rotating from there. Possibly rocking it in either direction will help let the kick gears let go?
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
