Driven shaft bevel gear + drive shaft bevel gear
- ReichardtRides
12 Oct 2019 10:12 #812306
by ReichardtRides
Driven shaft bevel gear + drive shaft bevel gear was created by ReichardtRides
Upon inspection and removal I noticed These clank and are not tight enough. The cause of all my woes it seems. I am wondering if it is simply a matter of tightening the tapered roller bearing, if that would even help/do anything? I’m assuming I may just need new pieces.
Any ideas, recommendations or advice would be greatly appreciated. Thank you.
- daveo
- Thank you received: 654
12 Oct 2019 15:10 #812323
by daveo
1982 KZ1100-A2
Replied by daveo on topic Driven shaft bevel gear + drive shaft bevel gear
Have you consulted the Kawasaki Factory Service Manual for your bike?
It may help to post pictures that show the issue.
:whistle:
:whistle:
1982 KZ1100-A2
- ReichardtRides
13 Oct 2019 13:20 #812370
by ReichardtRides
Replied by ReichardtRides on topic Driven shaft bevel gear + drive shaft bevel gear
Gladly. I’m sure the video will help demonstrate the issue I am encountering.
- ReichardtRides
13 Oct 2019 13:24 #812371
by ReichardtRides
Not seeing my attachments on the posts..
- ReichardtRides
13 Oct 2019 14:01 #812378
by ReichardtRides
Trying again
- Thank you received: 2063
13 Oct 2019 14:33 - 13 Oct 2019 14:34 #812379
by Scirocco
Replied by Scirocco on topic Driven shaft bevel gear + drive shaft bevel gear
Please use YouTube or other file hoster for Videos , the side has a Problem to shown Video and PDF files!
Last edit: 13 Oct 2019 14:34 by Scirocco.
- ReichardtRides
13 Oct 2019 14:36 #812381
by ReichardtRides
Test
- ReichardtRides
13 Oct 2019 14:37 #812382
by ReichardtRides
Oh ok. I’ll try and figure something else out.
- ReichardtRides
13 Oct 2019 15:07 #812385
by ReichardtRides
This should do it
This should do it
- daveo
14 Oct 2019 08:58 #812434
by daveo
1982 KZ1100-A2
No eBay APP ID and/or Cert ID defined in Kunena configurationI would replace the entire unit, before pulling gear assemblies and attempting repair by replacing shim spacers. Lots of hit-miss potential with that, and having it done professionally would likely be expensive.
Ebay:
Ebay:
1982 KZ1100-A2
- ReichardtRides
14 Oct 2019 09:00 #812435
by ReichardtRides
Do you know if the 82 piece is identical to the 81 year? Thanks
Man that S&H is a killer ..
- daveo
14 Oct 2019 09:12 #812437
by daveo
1982 KZ1100-A2
Exact same thing far as I know. KZ1100 front bevel gear case search shows gaskets and multiple options.
Shipping to me shows $14.05, but then I'm just one state away from the seller.
1982 KZ1100-A2
