Driven shaft bevel gear + drive shaft bevel gear
  • ReichardtRides
  • ReichardtRides's Avatar Topic Author
12 Oct 2019 10:12
#812306
Upon inspection and removal I noticed These clank and are not tight enough. The cause of all my woes it seems. I am wondering if it is simply a matter of tightening the tapered roller bearing, if that would even help/do anything? I’m assuming I may just need new pieces.
Any ideas, recommendations or advice would be greatly appreciated. Thank you.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Driven shaft bevel gear + drive shaft bevel gear
12 Oct 2019 15:10
#812323
Have you consulted the Kawasaki Factory Service Manual for your bike?
It may help to post pictures that show the issue.
:whistle:
1982 KZ1100-A2/1170 sleeper 😀
  • ReichardtRides
13 Oct 2019 13:20
#812370
Gladly. I’m sure the video will help demonstrate the issue I am encountering.
  • ReichardtRides
13 Oct 2019 13:24
#812371
Not seeing my attachments on the posts..
  • ReichardtRides
13 Oct 2019 14:01
#812378
Trying again
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Oct 2019 14:33 - 13 Oct 2019 14:34
#812379
Please use YouTube or other file hoster for Videos , the side has a Problem to shown Video and PDF files!
Last edit: 13 Oct 2019 14:34 by Scirocco.
  • ReichardtRides
13 Oct 2019 14:36
#812381
  • ReichardtRides
13 Oct 2019 14:37
#812382
Oh ok. I’ll try and figure something else out.
  • ReichardtRides
13 Oct 2019 15:07
#812385
This should do it
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
14 Oct 2019 08:58
#812434
No eBay APP ID and/or Cert ID defined in Kunena configurationI would replace the entire unit, before pulling gear assemblies and attempting repair by replacing shim spacers. Lots of hit-miss potential with that, and having it done professionally would likely be expensive.
Ebay:
  • ReichardtRides
14 Oct 2019 09:00
#812435
Do you know if the 82 piece is identical to the 81 year? Thanks
Man that S&H is a killer ..
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
14 Oct 2019 09:12
#812437
Exact same thing far as I know. KZ1100 front bevel gear case search shows gaskets and multiple options.
Shipping to me shows $14.05, but then I'm just one state away from the seller.
