1979 KZ750 Clutch push rod
  • ccammo
  • ccammo's Avatar Topic Author
11 Oct 2019 18:30
#812279
Just wondering if anyone knows what this is? Is it the clutch push rod? Am I missing anything from this picture?
Also, does anyone know the bolt(s) size/thread/etc for the engine sprocket cover? I think they didn't come with the bike when I purchased it. Or, if anyone knows where to buy them?
Thanks
  • TexasKZ
  • TexasKZ's Avatar
Re: 1979 KZ750 Clutch push rod
11 Oct 2019 19:33 - 11 Oct 2019 19:41
#812281
Yes, that is the clutch pushrod. Looks like the short bolts are 6 X 34. They are still available from Kawasaki. The longer ones will likely be 6mm, but longer and flanged.
www.partzilla.com/catalog/kawasaki/motor...750-b4/engine-covers
Last edit: 11 Oct 2019 19:41 by TexasKZ.
  • martin_csr
  • martin_csr's Avatar
11 Oct 2019 21:14 - 11 Oct 2019 21:14
#812288
While the engine-sprocket cover is off, you might want to clean up the neutral switch connection. My neutral light was glitchy, so I cleaned the switch & flag terminal. The terminal was loose, so I crimped it a little for a tight fit. I try not to ignore little stuff like that any more. :blush:
Last edit: 11 Oct 2019 21:14 by martin_csr.
