Balancing rotating assembly '78 650B2
- kawirider
06 Oct 2019 19:36
Where should I take /send my '78 650B2 rotating assembly to be balanced before a reassembly? I am having trouble finding a shop local or not that would even consider doing it. From what I understand, balancing may not be absolutely necessary, but I would like to get it done for my own piece of mind. I am using oversize pistons and a new used crank with matching rods from a different bike.
- DoctoRot
Re: Balancing rotating assembly '78 650B2
07 Oct 2019 00:01
are you looking for someone locally? APE racing does crank work I believe.
The following user(s) said Thank You: kawirider
07 Oct 2019 03:58 - 07 Oct 2019 03:59
Last edit: 07 Oct 2019 03:59 by TexasKZ.
- kawirider
07 Oct 2019 13:07
Im unsure as to how I didn’t find APE’s site when looking but they seem to be the most reputable source for this service so I will be sending my crank out to them.
Thank you for the input.
07 Oct 2019 16:05
Balancing shouldn't be necessary and would be quite unusual. My 750 which is almost identical to the 650 is very smooth running.
The following user(s) said Thank You: baldy110
07 Oct 2019 17:54
- kawirider
09 Oct 2019 13:40Do you not think balancing the crank is worth my time? I figured I’d go ahead and get it done since I have the motor apart.Nessism wrote: Balancing shouldn't be necessary and would be quite unusual. My 750 which is almost identical to the 650 is very smooth running.
- DFIGPZ
09 Oct 2019 13:58
I check weight on all rods & then pistons you should be fine.
1984 750 Turbo
The following user(s) said Thank You: Nessism, kawirider
