1983 kz750-4 cam swap
- brgtbird
05 Oct 2019 04:11
What year GPZ750 cams would fit a 1983 kz750-4 LTD and is there any noticeable benefit?
- DFIGPZ
Re: 1983 kz750-4 cam swap
05 Oct 2019 13:14 - 05 Oct 2019 13:14
83,84,85 and yes there would be a differnce also note GPZ750 used different base circle cams so be sure to adjust valve after install.
1984 750 Turbo
Last edit: 05 Oct 2019 13:14 by DFIGPZ.
- Daftrusty
05 Oct 2019 16:09
Note: the 1982 gpz cams will also fit, but they are not as aggressive of a profile.
Beware that the gpz750 turbo cams will fit, but are simply kz650 cams. You don’t want these!!
The 83-86 exhaust cams only will have a smaller base circle, so they will require thicker shims to set valve clearance.
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
