Street Fighter LTD wrote: Or warped steels from heat , or rust , or who knows without removing plates and doing a inspection of ALL parts.
One gasket is all it takes.
All great advice. As Dave stated, if you are having clutch issues, Dissect it and inspect everything carefully. The release mechanism under the sprocket cover (if the one with all of the little 1/8" steel bearing balls) is quite the can of worms to disassemble, clean, lube, then reassemble. Not for the faint of heart.
It may not be functioning properly. Be sure to clean and inspect this with your "patient" attitude in place.
The OEM clutch plates also have orientation to look for when installing the friction plates. I have them laid out in the proper orientation in the clean oil soaking pan during re-assembly to make assembly a little closer to idiot proof.
The steels also have a "sharp" side that can affect disengagement on the clutch hub. The basket should not have grooves worn where the plates ride to prevent the plates from hanging up. All part of the term "inspect".
Attachment not found
