KZ900 Exhaust mounting bolt size?
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
23 Sep 2019 12:51
#811215
I'm switching out the 4 in 2 Jardine exhausts on my KZ900 with a set of repros from Z1parts. The mounting bushings from the 4 in 2s are still good so all I need are the two mounting bolts. Instead of paying 21 bucks for them was hoping to find a couple suitable ones at the hardware store. Parts list shows these are "92003-180 Bolt, Hex Head, 10X104" I can get the diameter from my 4 in 2 bolts, all I need is the length of the stock bolts. If anyone knows or doesn't mind measuring theirs I'd appreciate it.
KZ900; Z1
  • Warren3200gt
  • Warren3200gt's Avatar
Re: KZ900 Exhaust mounting bolt size?
23 Sep 2019 13:03 - 23 Sep 2019 13:06
#811218
10mm x 104mm
Last edit: 23 Sep 2019 13:06 by Warren3200gt.
The following user(s) said Thank You: Robb2018
