KZ550 parts help
  • prichmon
  • prichmon's Avatar Topic Author
KZ550 parts help
16 Sep 2019 07:03
#810920
Good morning KZR forum;
I recently purchased a 1984 KZ550LTD with 8000 hard used miles on the bike. I am setting the bike up for my daughter and son in law.. The PO has bashed both front and rear air boxes. I also have 1 diaphragm slide which is hanging up from being too stiff.
Is there a reasonable place to purchase new/repaired slides?
Would anyone know where I could find a compatible airbox set? Or should I go with pods?
Thank you for your time.
Rich
  • martin_csr
  • martin_csr's Avatar
Re: KZ550 parts help
16 Sep 2019 07:21 - 16 Sep 2019 07:26
#810922
Partzilla has diagrams with a cross-reference.
There's a ZX550 airbox listed on EB that looks to be in decent to good condition. at reasonable cost if not cheap. $35T is cheap IMHO.
Last edit: 16 Sep 2019 07:26 by martin_csr.
  • prichmon
17 Sep 2019 11:12
#810973
No eBay APP ID and/or Cert ID defined in Kunena configurationI saw one for a GPZ/ZX but not the KZ550. I can't seem to find it.
Is it this one ??? I need the front and rear airbox.
  • martin_csr
17 Sep 2019 12:09 - 17 Sep 2019 12:11
#810976
As noted in the reply, search for ZX550 airbox. There are actually 2 listed. I only saw one the other day.
Last edit: 17 Sep 2019 12:11 by martin_csr.
  • 73z1
  • 73z1's Avatar
18 Sep 2019 06:14 - 18 Sep 2019 06:16
#811009
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Last edit: 18 Sep 2019 06:16 by 73z1.
  • martin_csr
18 Sep 2019 13:17 - 18 Sep 2019 15:21
#811026
That's an earlier 550 airbox. From the diagrams at Partzilla the 84 550 Ltd Shaft airbox is different and has separate Front & Rear sections. I have no idea if the earlier airbox will fit.
Last edit: 18 Sep 2019 15:21 by martin_csr.
