Will these fit an 83 KZ 1100?
  • tthunderdan
  • tthunderdan's Avatar Topic Author
27 Aug 2019 15:08
#809949
These are listed locally, I wonder if they are usable on a KZ1100.
pittsburgh.craigslist.org/mpo/d/blairsvi...aust/6944054827.html
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
  • tthunderdan
Re: Will these fit an 83 KZ 1100?
27 Aug 2019 15:32
#809952
seller claims from an 83 gs1100
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
  • baldy110
  • baldy110's Avatar
27 Aug 2019 16:23 - 27 Aug 2019 16:24
#809955
Those are for the Suzuki GS1100. So based on that info I would say no they wont fir your KZ1100. But then with a torch and welder you can make anything fit.
Last edit: 27 Aug 2019 16:24 by baldy110.
The following user(s) said Thank You: tthunderdan
  • Nessism
  • Nessism's Avatar
27 Aug 2019 16:36
#809958
I don't know if they would fit but I do know they are worth a good deal more than advertised. Buy them for flipping? If you pack right they will fit within the UPS size requirements before the rate jacks up too high. I know because I flipped two almost identical systems for Katana's.
