pro stock 2v web cams
  • dmogas
  • dmogas's Avatar Topic Author
24 Aug 2019 18:31
#809788
putting a 1500 cc mtc billet block on meangreen j crank gpz domes gpz head 44 i 38e decked .100 / has 14x andrews cams and id like to use web/ what would be a good cam choice was using 26web and 470 exh. / should use 1 in. base circle cams now ??? thanks
putting a 1500 cc mtc block on meangreen . I bought a GPZ head 46 i 38 e what web cams should i go with ???
  • DFIGPZ
  • DFIGPZ's Avatar
Re: pro stock 2v web cams
24 Aug 2019 19:59
#809789
What CR , what base circle has valve depth for need way more info intended use of engine ?
1984 750 Turbo
