82 1100 How do I set the timing for 2 -n- 3 without having marks on rotor?
- Gdailey2112
- 82 KZ1100D1
24 Aug 2019 13:15
How does one set the timing for 2 -n- 3 without having marks on rotor? Please and thanx.
1982 KZ1100D1
Re: 82 1100 How do I set the timing for 2 -n- 3 without having marks on rotor?
24 Aug 2019 13:30 - 24 Aug 2019 13:31
If you set the Timing for #1/4 (F or TDC) the Timing for #2/3 are exact 180 degree off as it should.
Last edit: 24 Aug 2019 13:31 by Scirocco.
- loudhvx
24 Aug 2019 13:49 - 24 Aug 2019 13:50
There might be a T mark for TDC on 2 and 3. It's usually there for valve lash measuring etc.
Just get a sharpie marker or an awl and scratch marks into the advancer. Make them the same distance from 2-3 T as the other ones are from 1-4 T (to F and double lines), and in the same direction.
Like Scirocco said, they should end up exactly 180 degrees from the 1-4 marks.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 24 Aug 2019 13:50 by loudhvx.
- daveo
24 Aug 2019 14:13
The timing on a stock J-motor is not adjustable. You are pretty much stuck with what it is, and it should be correct if the cam-sprocket marks line up with the head surface when installing the cams. That is, unless the three mounting holes in the pickup coil plate have been slotted.
That is one reason I changed the stock ignition out for a Dynatek 2000, which has performed flawlessly and requires no maintenance.
1982 KZ1100-A2/1170 sleeper 😀
24 Aug 2019 14:16 - 24 Aug 2019 14:17
No eBay APP ID and/or Cert ID defined in Kunena configurationThere should be a T mark for 2-3 >> T |
.... EB item. see 3rd pic.
Last edit: 24 Aug 2019 14:17 by martin_csr.
24 Aug 2019 14:32
Yes Martin but the T on #2/3 position are missing the #2/3 typo on the advancer body, very funny.
25 Aug 2019 06:23
Yes. Just illustrating that there is a 2-3 mark.
- Gdailey2112
- 82 KZ1100D1
25 Aug 2019 15:03
Ohhh ok I see, and yes there is a T mark for TDC but I will simply measure and scribe. Thanks all!!
1982 KZ1100D1
