83 gpz1100 cam compatibility
  • ned37
  • ned37's Avatar Topic Author
23 Aug 2019 10:51
#809693
tearing down my 83 gpz1100 to replace cyls back to stock. when i pulled the cams, the wear pattern on the bearing shells tells me the exhaust cam is bent. (i always thought it sounded a bit noisy).
i'll be looking for a replacement and if the gpz cam is hard to find (or comes too dear), is it possible to go with a kz set as an alternative. would the f.i. computer balk at it? is it a direct replacement? anybody have info about this?
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 83 gpz1100 cam compatibility
23 Aug 2019 14:21
#809700
I did some measurements during my GPZ 1100 cam swap.
The GPZ1100 cams had a 28,25 - 28,30 mm base cycle (IN and EX cam). The Z1B IN cam had a 26,70 mm / the EX cam had a 27,45 mm base cycle.
So you need thicker shims if you want to run Z1 / KZ cams.
  • baldy110
  • baldy110's Avatar
23 Aug 2019 15:49
#809704
I've got a good set of GPZ1100 cams if your interested.
The following user(s) said Thank You: ned37
  • ned37
24 Aug 2019 06:35
#809736
?? i thought the cams were the same from intake to exhaust. what about an '82 kz1100?
Verde Valley, AZ
  • ned37
24 Aug 2019 06:37
#809737
pm me about it. thanks
Verde Valley, AZ
  • ned37
24 Aug 2019 20:06
#809790
i rigged up a crude v-block setup and found the runout on the intake cam was less than .001"- lookin good. ( max allowed is .004)
when i did the exhaust, i expected it to be out of tolerance, but max appears to be around .003". but i'm tired (didn't get my nap) and will do it again tomorrow.
Verde Valley, AZ
  • ned37
25 Aug 2019 17:18
#809845
.00325 it is, so i guess that's what new cam bearing shells look like after 500 miles with a slightly bent cam.
all the journals are within spec, too.
Verde Valley, AZ
