Gpz1100 cams
  • headly666
  • headly666's Avatar Topic Author
Gpz1100 cams
21 Aug 2019 02:28
#809585
Gday guys how are you all?
Was after some thoughts on cams, I have some 84 gpz1100 cams with sprockets to suit z1 use.
Would these be better suited for a street motor with ported head, 1100 pistons , ignition and a small nitrous shot or are they better for a street turbo build I have both motors just curious as to which would be the best option.
Cheers for any advice
  • zed1015
  • zed1015's Avatar
Re: Gpz1100 cams
21 Aug 2019 03:47
#809586
They are suitable for either.
The following user(s) said Thank You: headly666
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Gpz1100 cams
21 Aug 2019 05:28
#809588
For GPZ1100 cams you need some APE parts. The CCIA is needed for a 1000j/GPZ1100 head on Z1 engine.
  • headly666
Re: Gpz1100 cams
21 Aug 2019 05:46
#809589
Ok cheers mate
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Gpz1100 cams
21 Aug 2019 13:50
#809597
and you loose tachometer drive.
1984 750 Turbo
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Gpz1100 cams
21 Aug 2019 14:51
#809599
An electronic Tachometer with stop lamp is available.
z-fever.de/shop/en/product_info.php?info..._drehzahlmesser.html
  • drdamn
  • drdamn's Avatar
Re: Gpz1100 cams
03 Sep 2019 13:22
#810293
Let me know if you'd be interested in selling those. Im in need of a set to finish my build.
