J-Model Base Gasket
- richard-GPZ
J-Model Base Gasket
14 Aug 2019 12:01
My bike is an 1983 GPZ-1100 and I was wondering if anyone else has trouble with the base gaskets from Cometic interfering with front cam chain guide?
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
Re: J-Model Base Gasket
14 Aug 2019 12:19 - 14 Aug 2019 12:20
Welcome Richard, can you upoad some pics of your base gasket Trouble?
Last edit: 14 Aug 2019 12:20 by Scirocco.
- richard-GPZ
14 Aug 2019 12:55 - 14 Aug 2019 12:58
If you look close at this gasket I used in a mock assembly it was bent over by the front cam chain guide.
Last edit: 14 Aug 2019 12:58 by richard-GPZ. Reason: picture missing
14 Aug 2019 13:22
Did you install it backwards?
14 Aug 2019 13:25 - 14 Aug 2019 13:31
In my opinion you have flip over the front to rear aka upside down surface of the gasket. Is any site of the gasket stamp with an up or down Symbol?
edit : add a pic of the bottom rear gasket.
Last edit: 14 Aug 2019 13:31 by Scirocco.
- richard-GPZ
14 Aug 2019 13:32
No sir. I used the dowel pins and they won't fit the back holes of the gasket if you put it in backwards.
14 Aug 2019 13:39 - 14 Aug 2019 13:41
I am not so skilled with the J-model engines but maybe you have to put in the chain guide first and then on top the base gasket.
Last edit: 14 Aug 2019 13:41 by Scirocco.
- richard-GPZ
14 Aug 2019 13:57
The front cam chain guide is put in after the gasket and block are installed. It fits into the block then the head gasket and head go on top.
- DFIGPZ
- richard-GPZ
14 Aug 2019 14:37DFIGPZ wrote: Common trim gasket .
I take it you have had the same problem. My issue is I want to use a rubber coated steel gasket. I don't believe I will be able to easily trim it.
- zed1015
15 Aug 2019 05:11 - 15 Aug 2019 05:12
Are you sure that base gasket isn't for the earlier motor.
The slot for the cam tunnel is usually cut wider at the end where the guide sits on the 'J'..
Last edit: 15 Aug 2019 05:12 by zed1015.
The following user(s) said Thank You: richard-GPZ
- old_kaw
15 Aug 2019 07:19
That gasket doesn't look to be the right one for a J motor. This is the OEM paper base gasket for my 81 Kz1000.
Attachment not found
1981 Kawasaki Kz1000K1
