Another Cam ID request.
  • 1981kz750ltd
  • 1981kz750ltd's Avatar Topic Author
11 Aug 2019 16:28
#809049
Cams in the 77 1000 engine with a J model head.
Cast # EP 14 CWC
Stamped on intake cam end.
6 97 WEB CAM
109
EXHAUST cam 6 97 WEB CAM 109
  • TexasKZ
  • TexasKZ's Avatar
Re: Another Cam ID request.
12 Aug 2019 19:53
#809087
The following user(s) said Thank You: 1981kz750ltd
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
12 Aug 2019 20:04 - 12 Aug 2019 20:05
#809088
1981kz750ltd wrote: 6 97 WEB CAM 109
Just in case that link isn't clear... As you likely guessed, the cam grind number is stamped on the end of the Web cams. Based on the numbers you gave it seems very likely you have the "109" grind cams.
www.webcamshafts.com/pages_vehicles/moto...c_001730_002572.html
My dad's '74 Z1
'00 ZRX1100
Last edit: 12 Aug 2019 20:05 by DOHC.
