82 1100 spectre 7,800 miles engine craps out in topp three gears
  • scott961
  • scott961's Avatar Topic Author
04 Aug 2019 11:13
#808693
my 1100 runs great 1st and 2nd gear by 5th gear has no power hit the throttle you can hear it missing I know I don't ride it enough ive had people tell just put some miles on it. It might come out of it.
  • Nessism
  • Nessism's Avatar
Re: 82 1100 spectre 7,800 miles engine craps out in topp three gears
05 Aug 2019 06:54
#808738
Is the bike stock or modified? And have you been through the factory Kawasaki manual for your bike and made sure all the required maintenance tasks are up to date?
The following user(s) said Thank You: scott961
  • TexasKZ
  • TexasKZ's Avatar
05 Aug 2019 07:25
#808742
If it has been sitting unridden for long periods of time, there is a good chance that the carbs are gummed up. No matter, the routine maintenance is always the place to start. Doing all the maintenance will eliminate possible causes and make diagnosis less of a shot in the dark.
  • scott961
05 Aug 2019 14:16
#808764
thanks texaskz
  • scott961
05 Aug 2019 14:18
#808765
thanks Nessism
  • old_kaw
  • old_kaw's Avatar
05 Aug 2019 14:22 - 05 Aug 2019 14:23
#808767
If it is winding out in all 3 lower gears, it may be a problem with the fuel filter / screen being plugged, or a plugged tank vent. The gas cap vent is probably the easiest of all to check, since it's right on top. Both will limit / hinder fuel flow into the carbs.
1981 Kawasaki Kz1000K1
Last edit: 05 Aug 2019 14:23 by old_kaw.
