1983 kawa 1100 LTD oil filter question
- howfast54
02 Aug 2019 04:44
I recently bought a project bike 83 1100 Ltd. Pulling the oil filter assembly out I failed to notice if the "cup" was on top or the bottom of the oil filter. I cannot find a diagram anywhere online and my Clymers maunual is on a wagon train it sems. The washer was missing. Has anyone used an electrical reducing washer, they are the right size and only 25 cents.
Re: 1983 kawa 1100 LTD oil filter question
02 Aug 2019 05:12 - 02 Aug 2019 05:46
No eBay APP ID and/or Cert ID defined in Kunena configurationThe 81-83 1000/1100 chain drive Kawasaki service manual shows the cup on top of the filter,
as does the oil pump diagram at Partzilla for the 83 1100-L1 Ltd Shaft. I'm assuming your bike is the Ltd Shaft.
I would get the Kawasaki FSM. A number of them are available on eebbaayy & several at reasonable cost if not cheap. Kawasaki service manuals have a model application chart on the back cover, so make sure your motorcycle is on the list.
....EB search = KZ1100 Shaft manual.
Last edit: 02 Aug 2019 05:46 by martin_csr.
- old_kaw
02 Aug 2019 06:15 - 02 Aug 2019 06:35howfast54 wrote: I recently bought a project bike 83 1100 Ltd. Pulling the oil filter assembly out I failed to notice if the "cup" was on top or the bottom of the oil filter. I cannot find a diagram anywhere online and my Clymers maunual is on a wagon train it sems. The washer was missing. Has anyone used an electrical reducing washer, they are the right size and only 25 cents.
Download this manual:
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Here is the filter breakdown snip: ** any washer that fits properly should be fine. make sure it is not larger than the rubber grommet I think the 1/2" X 1" reducer washer may fit. Don't quote me on this, since I haven't tried it myself.**
Attachment not found
The assembled filter.
1981 Kawasaki Kz1000K1
Last edit: 02 Aug 2019 06:35 by old_kaw.
