1075 piston head gasket contact
  • bikedog
  • bikedog's Avatar Topic Author
26 Jun 2019 05:49
#806473
so my cylinder was milled and I have a +.005" deck height.(piston above the cylinder)
Im using a 72mm cometic head gasket
whats happening is the steel rings in the gasket are all slightly out of round(.01"-.02")
and the outside diameter of the piston contacts the areas of the gasket that protrude into the bore
Im dremel grinding a new gasket now to provide clearance
has anyone run into this situation
doing some research I found that running + deck height to improve squish band is not uncommon
thanks,Steve
76 Z1
PSP 1075 stage 2 head
34mm mikunis
suzuki bandit 1250 swingarm
2012 hayabusa frontend and wheels
