Clutch ball and ramp actuator question
- ric812
12 Jun 2019 18:03
I am missing the ball bearings for the ball and ramp actuator for the clutch. Does anyone know where I can find these? I was working on a sticky clutch handle when I took the sprocket cover off and pulled out the ball and ramp actuator (pictured below) and noticed that the ball bearing where missing. I have not had this bike on the rode since I bought it.
1982 Kawasaki KZ750M Twin CSR
- loudhvx
Re: Clutch ball and ramp actuator question
12 Jun 2019 19:19 - 12 Jun 2019 19:20
There are three types found on Kz's, but I'm not sure about the 750 twin.
There is a type that uses a plain screw type. Then there is a type using balls with a circular ramp. Finally there is a type that uses balls with pockets.
The type with balls and pockets are more common on the later years I think.
If I can remember to check when I get home, I'll try to measure the balls for the ball-pocket type, and maybe post a dissected photo so you can see if that is what you have.
If all you need are the bearings, a bicycle shop might have them loose so you can buy singles.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 12 Jun 2019 19:20 by loudhvx.
12 Jun 2019 20:47
According to tha parts diagram, your bike uses the same actuator as the liter bikes of that time.
If Lou can't find one, I should have one knocking around the garage I can measure.
www.partzilla.com/catalog/kawasaki/motor...twin-kz750-m1/clutch
13 Jun 2019 05:37 - 13 Jun 2019 05:40
I would search the part numbers from Partzilla on eebbaayy & compare the parts there to what you've got. EB pics are handy for stuff like this, especially pics of NOS parts. Partzilla has photos of some parts.
Last edit: 13 Jun 2019 05:40 by martin_csr.
- loudhvx
13 Jun 2019 06:19 - 13 Jun 2019 07:12
Ok, so that is the ball-pocket type. You will need more than just the loose ball bearings. You will need the "cage" which holds the balls. You can see it listed on Texas's link. 92045-1001 It shows in stock on that link, but I don't know if that means they actually have it. You might find it somewhere available.
I attached an exploded photo of the {b] Kz550 [/b] version. you can see the 3 balls are in a stamped, sheet-metal holder, or "cage". Ignore the actuator part number on this photo. The part number is different on the bigger bike, but the part number for the ball-bearing-cage is the same.
I also attached a diagram, below, of how it works and how to adjust it.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 13 Jun 2019 07:12 by loudhvx.
- loudhvx
13 Jun 2019 07:16
No eBay APP ID and/or Cert ID defined in Kunena configurationWow, that is expensive on ebay $30. I bet you could get the whole assembly cheaper, but here's the link.
1981 KZ550 D1 gpz.
Other links.
Other links.
- ric812
13 Jun 2019 07:43
Here is a picture of the internals. Will the part that has been listed earlier be the right one for this setup?
- loudhvx
13 Jun 2019 08:30
Yes, but in my opinion it's overpriced.
1981 KZ550 D1 gpz.
Other links.
Other links.
- ric812
13 Jun 2019 08:32
Thank you but T least I have a part number which I could not find before.
13 Jun 2019 12:21
Since it is an active part number, your local Kawasaki dealer may have one lying around, or can order one for you. Some folks have complained about Partzilla not always having in stock what they say they have, but I have had good luck with them.
- ric812
13 Jun 2019 12:30
I looked up partzilla and they have a few in stock at $6 or so, which is alot cheaper that the ebay price.
- ric812
13 Jun 2019 12:32
Thank you all for the help. This forum has been great help while I am getting mu KZ up and running.
