Police 1000 spongy shifter
- Setton
11 Jun 2019 19:40
So I have a kz1000p and had a little accident, nothing too serious. I have a kz specialist repair it, and I get it back, and it seems like the shifting is spongy now. It used to be very crisp, where you could know right away that it shifted from the physical clunk you could feel. Now it just shifts and it doesn't give me feedback about whether I'm in first or fifth. Trying to shift up from fifth feels the same as sitting up from any other gear and vice versa for first and shifting down . The only indication I have for shifting is rpm or the clunk from going from neutral to first.
What's could be going on? I know the heel toe shifter was replaced... But that doesn't seem like it's be the cause.
KZs I own
1982 KZ750-H3 LTD (frame's bent, no longer rideable, RIP)
1982 KZ1100 LTD Shaft (thought it was a Spectre)
1988 KZ1000 Police
1989 KZ1000 Police (basket case)
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
I don't understand soup. Put a flower on my nose.
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
- ThatGPzGuy
Re: Police 1000 spongy shifter
12 Jun 2019 05:56
Check the linkage. There are a lot of places where there can be slop. It might just be loose. Also check the alignment. The shifter has to be a certain distance from the floorboard front and back.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Setton
12 Jun 2019 20:06 - 13 Jun 2019 14:03
Well I reported it to the mechanic that I had working on the bike after the accident. He did something to the shifter. That made it worse. I was out and about and it suddenly stopped letting me up shift without stomping it. That eventually knocked something loose on the linkage, and now it's dark and I can't see well enough to see if I can fix it.
He did say the teeth on the shifter are smoothed down. The thing is, the new shifter came with its own linkage. If I can get the bike fixed enough to get it down to the shop (currently it's in 3rd gear) I can likely get the old linkage and use it until the NOS linkage that we bought yesterday gets in.
(edit)
I fixed the problem myself... I switched to the old linkage, which had better teeth to grab the shift rod, and adjusted the rod that links the pedals to that. It's shifting a lot better now, just like I've been used to.
(edit)
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
Last edit: 13 Jun 2019 14:03 by Setton.
