Cam has black spots on intake side
  • Kawi77
  • Kawi77's Avatar Topic Author
  • 06 16 60
11 Jun 2019 14:58
#805529
Bike has been sitting for 14 years got it running run strong as top end chatter went to adjust shims and cam has black spots on it could this be from just sitting new member thanks for your help
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cam has black spots on intake side
11 Jun 2019 15:09 - 11 Jun 2019 15:11
#805532
Any pics of the black spots on the intake cam?
Last edit: 11 Jun 2019 15:11 by Scirocco.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Jun 2019 15:09
#805533
What are the measurements?
  • Kawi77
  • 06 16 60
11 Jun 2019 15:23
#805535
I'm having a hard time getting pictures dow.
nload I will try again thank you. #1int 005. 250. #1exh0.15 270. #2. O.05. 255. 0.20. 270. #3. 0.10 230. 0.20. 280. #4 0.04 230. O.10. 275
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • Kawi77
  • 06 16 60
11 Jun 2019 15:26
#805536
As far as the pictures go I'm sure it's something I'm not doing right
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Jun 2019 15:28
#805537
I was going to suggest cam slap.
  • Kawi77
  • 06 16 60
11 Jun 2019 15:32
#805538
What exactly is Cam slap and thank you for your help
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Jun 2019 15:38
#805540
I've noticed a pattern on the cam lobes if they weren't adjusted correctly. It seems to go away. On the tips of the lobes are another matter. That could be wear of the hard face.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Jun 2019 15:39
#805541
Have to ask, do you talk about black spots on the surface of the cyl. head intake ports?
  • Kawi77
  • 06 16 60
11 Jun 2019 15:49
#805542
The cam lobes themselves on a tips look fine
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • Kawi77
  • 06 16 60
11 Jun 2019 15:50
#805543
Just on the backside of the cam away from the tips could be from sitting I don't know never seen this before
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
  • Kawi77
  • 06 16 60
11 Jun 2019 15:52
#805544
Thank you for your help I really appreciate it I'm going to order some shims get it all put back together and go from there
Stevevaughn152
77 kz900
77ltd1000
79kz1000
80ltd1000
