kz650b3 clutch rod
- jamesjc1200
kz650b3 clutch rod
06 Jun 2019 17:05
I have a kz650b3 engine and i'm looking for a clutch push rod. The one that came out is 7 mm and about 270mm long (estimated) and has 2 lines on it instead of 1 but if i look up the part number it lists 13116-035 which i believe is 8 mm and 270mm long. I have the 8 mm one that came out of a kz550 but it seems to wide in diameter to fit inside where the rod goes i have attached a picture
if anyone can help that would be great
Attachment not found
1977 KZ650B
Re: kz650b3 clutch rod
07 Jun 2019 06:18 - 08 Jun 2019 06:09
No eBay APP ID and/or Cert ID defined in Kunena configurationWhy do you believe the 13116-035 push rod is 8mm? I have no idea what size it should be. The part number for my 81 KZ650-CSR is 13116-1007 & from the cross-reference at Partzilla it's the same as the 550 models. So maybe yours should be 7mm, then Kawasaki changed it to 8mm for the 81-on 650s & other models. but I don't know.
The transmission cover oil seal for the 650-B3 push rod is #TC7187, while the 650-CSR is SD-8187.
I'll guess the first number in each is the I.D. >> 7mm for the B3 & 8mm for the CSR.
KZ650-B3 clutch push rod 13116-035
Last edit: 08 Jun 2019 06:09 by martin_csr.
The following user(s) said Thank You: loudhvx, jamesjc1200
