Headgasket
  • Kwakers
  • Kwakers's Avatar Topic Author
Headgasket
23 May 2019 22:56
#804474
Athena gaskets DON'T touch them. I replced the topend gasket set after i holed one of my pistons and its leaked ever since. So im now getting fed up with an oily foot . So its strip down again i thought I'd buy an Athena gasket set unfortunately it didn't contain the rubber o'rings had to buy them separately along with the cam end half moon seals. I cleaned everything and inspected and reassembled reset the shims for the valve clearance. Started the motor up took it for a blast. And you've guessed its still leaking in the same place. Has anybody gad the same issue with these aftermarket gaskets? Im going to replace the headgasket again but use a genuine kawasaki gasket. So I'll get back with the results in a few weeks time as ive got to save up for another gasket there not cheap.
  • hardrockminer
  • hardrockminer's Avatar
Re: Headgasket
24 May 2019 02:16 - 24 May 2019 04:27
#804479
I always use OEM gaskets for the engine, although in the past I've used others. Vesrah is good.
When you mentioned o-rings I assume you mean the ones around the cylinder sleeves?
Just wondering....did you torque the head down in the correct bolt sequence? Did you use a torque wrench?
Last edit: 24 May 2019 04:27 by hardrockminer.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Headgasket
24 May 2019 03:43
#804481
OEM gaskets or Cometic for me
No Problems
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Headgasket
24 May 2019 05:19
#804483
What bike?
Did you heat cycle the new gasket once & re-torque again when cold before ridin'?
Agree with the above re: correct assembly process and brands. Never heard of Athena.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Nessism
  • Nessism's Avatar
Re: Headgasket
24 May 2019 05:35
#804485
Athena gaskets suck. I've posted these photos several times previously as a warning but not many people search out such info.
The damage occured because the base gasket couldn't take the clamp load. I retorqued the head after a rebuild and found the torque super low. After the second retorque the gasket extruded out of place. Never again.
[img
IMG_1931 by nessism , on Flickr
[img
IMG_1930 by nessism , on Flickr
The following user(s) said Thank You: loudhvx, 650ed, slmjim+Z1BEBE, Scirocco, Kwakers
  • KZB2 650
  • KZB2 650's Avatar
Re: Headgasket
24 May 2019 08:20
#804505
Thinking it was your warning Ness that steered me away from these green gaskets and to oem. Used the Wiseco head gasket that came with the kit but everything else oem.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • slmjim+Z1BEBE
Re: Headgasket
24 May 2019 09:43
#804512
Nessism wrote: Athena gaskets suck.
Looks like melted plastic.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Kwakers
  • Kwakers
Re: Headgasket
24 May 2019 12:50
#804520
Yep used a torque wrench. correct sequence, followed the manual to the letter. It wasn't leaking with the original gasket it only started after fitting the after market gaskets been a mechanic for over 40 years so i feel i know what I'm doing apart from trying to things cheaply but i think ive learned my lesson
  • hardrockminer
Re: Headgasket
24 May 2019 15:17
#804524
I didn't mean to insult you with my questions about torque wrenches. It normally would be a given, but some people......well you never know.
  • Kwakers
Re: Headgasket
26 May 2019 22:22
#804656
None taken thanks
Just done 200 miles and no oily foot, so the jury's out for the moment. i resorted to a wynns oil additive its supposed to stop minor oil leaks and its safe apparently. I even put a small amount of epoxy resin over the seepage as the oil is not leaking under pressure, so far so good, ill kerp you posted
The only issue i had on my journey was the balance pipe between the down pipes worked its way to one side so i had a noisey ride home. Need to get some new seals for the pipe.
  • Kwakers
Re: Headgasket
26 May 2019 22:36
#804657
Wish i read your post first would have saved me time and money ive now put a genuine base gasket on . Which is holding up fine but i still have the afternarket athena head gasket on and keeping fingers crossed it was leaking or seeping at the front ot the head between the down pipes but its now stopped after putting in some Wynns oil additive which is supposed to stop small leaks. I KNOW it's not very proffesional but needs must. Had to try something as i promised to visit my daughter while she was camping with her family . So at the moment no oily foot after 200 miles
  • VTEC
  • VTEC's Avatar
Re: Headgasket
02 Jun 2019 09:29
#805025
Has anyone used the Cometic MLS head gaskets? I think they discontinued the composition gaskets that leak, but haven't heard anything on the new MLS.
KZ1000-K2
ZRX1100
XR400R
