Cylinder base gasket, dry or wet?
  • scubaanders
  • scubaanders's Avatar Topic Author
19 May 2019 09:49
#804168
When I was a kid I was told to oil paper gaskets before fitting them and so I did and all was well, but as I am currently assembling my Gpz750R1 I am struck by the fact that the FSM doesn’t say anything about fitting the cylinder base gasket wet or dry.
What is your take? Shall the cylinder base gasket go on dry or wet?
Brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • Nessism
  • Nessism's Avatar
Re: Cylinder base gasket, dry or wet?
19 May 2019 10:53
#804173
Dry, assuming you are using an OEM Kawasaki gasket. Oil in the valve cover gasket will aid removal later for valve adjustments but that's the only gasket I'd oil.
The following user(s) said Thank You: scubaanders
  • scubaanders
19 May 2019 12:35
#804181
As said, I was always told to fit them wet so they should be easier to remove, but dry it is then.
Tks Nessism
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
