clincher piston tolerance
- Sayonara
- The faster the better
29 Apr 2019 13:00
I am doing an engine from 1200 to 1260 with a wiseco domes piston kit. the guy that is going to do the bores is asking the tolerance between the piston and the wall?
could you guy help?
could you guy help?
I grew up riding and fixing all sort of small bike until I inherited A 1977 GS 750 when I was 16, that changed my life completely I love metric bike and I own a few fully working and have some projects.
- zed1015
Re: clincher piston tolerance
29 Apr 2019 13:42 - 29 Apr 2019 13:44
2 thou ( 0.051mm)
Make sure he bores the cylinders in either 3 - 1 - 4 - 2 or 2 - 4 -1 - 3 sequence to avoid inter cylinder heat transference which will skew the finished clearances unless the block is allowed to fully cool between each pass.
Last edit: 29 Apr 2019 13:44 by zed1015.
- Sayonara
30 Apr 2019 04:37
Thank you very much.
