84 zx550 oil pan
  • Quigleyje
  • Quigleyje's Avatar Topic Author
84 zx550 oil pan
22 Apr 2019 06:41
#802600
Is the 84 zx550 oil pan aluminum?( Not near my bike right now) I have stripped drain plug from PO found a repair plug that gets welded in but before I order need to know what metal it is.
81/84 kz/zx550
  • martin_csr
  • martin_csr's Avatar
Re: 84 zx550 oil pan
22 Apr 2019 07:23 - 22 Apr 2019 07:47
#802604
It's probably aluminum/aluminum-alloy.
Here's an alternative fix from the vulcan gadget fixit page >> Stripped oil plug! Not a problem! >> self-tapping oil drain plug by Oil-Tite.
His wasn't completely stripped, so it may not work in all applications. main vulcan fixit page >> vulcangadgets.com
Last edit: 22 Apr 2019 07:47 by martin_csr.
The following user(s) said Thank You: Quigleyje
  • Quigleyje
22 Apr 2019 07:35
#802608
I think it's aluminum but not sure The PO already repaired it once it has a 14m x 1.25 drain plug now so not sure if it can be retapped I haven't taken it off to check it yet. The weld in bung might work best.
81/84 kz/zx550
  • martin_csr
22 Apr 2019 07:47
#802611
Have you checked EB for a good replacement?
  • Quigleyje
22 Apr 2019 08:01
#802613
Yeah there's a couple nice ones on eBay but of o can fix it for under $20 it would be better. Cause I'm looking at 50-60 on eBay. Bit that might be my best option. I have a perfect one from my 81kz550 engine but it's not set up for the oil cooler.
81/84 kz/zx550
  • martin_csr
22 Apr 2019 08:05 - 22 Apr 2019 13:51
#802614
Okay. wasn't sure what total cost you were looking at, for getting it welded. I'd have to find a place & pay someone. I did see a couple of pans on EB for $40T.
Last edit: 22 Apr 2019 13:51 by martin_csr.
  • Quigleyje
22 Apr 2019 08:34
#802616
Welding is free my brother can do it for me. That's why I was thinking that route but a new(used) pan might be better
81/84 kz/zx550
