Early Z1 Sprocket Cover
  • asphalt900
  • asphalt900's Avatar Topic Author
21 Apr 2019 07:08
#802526
Looking to verify correct 1973 sprocket cover. I know the Super early covers did not have the shifting pattern. Later came the covers with the small N and large N casting font. Sooo Question is did small N come first or large N. I have both versions that are cast to retain the chain oiler pump. Thank-You
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Early Z1 Sprocket Cover
21 Apr 2019 13:18
#802553
Large N on the early castings with shift pattern.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • asphalt900
22 Apr 2019 05:23
#802597
Thanks for the response slmjim! On a side note I noticed in another post You were looking for some block connectors for the Z junction box, did You find what You were after? I made a forked tool years ago to remove the female connector spades in those blocks, males are a lot easier. Made the tool to keep things tidy, no unsightly spliced wires.
